Ana içeriğe geç
Nabi 2 Battery Replacement
Neye ihtiyacın var
  1. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 1. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 2. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 3.
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Battery Replacement: adım 2, 2 resimden 1. Nabi 2 Battery Replacement: adım 2, 2 resimden 2.
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Battery Replacement: adım 3, 3 resimden 1. Nabi 2 Battery Replacement: adım 3, 3 resimden 2. Nabi 2 Battery Replacement: adım 3, 3 resimden 3.
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Battery Replacement, Battery: adım 4, 3 resimden 1. Nabi 2 Battery Replacement, Battery: adım 4, 3 resimden 2. Nabi 2 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Use the spudger to pop the battery out of place and set it aside.
  5. Nabi 2 Battery Replacement: adım 5, 3 resimden 1. Nabi 2 Battery Replacement: adım 5, 3 resimden 2. Nabi 2 Battery Replacement: adım 5, 3 resimden 3.
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michelle
851 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Lacy Spring 2016 USF Tampa, Team 4-3, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G3
4 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
Was hoping you could provide the replacement part number for this battery.
ellenanders5 - Yanıt
It shows on the picture: 1ICP6/68/112
Zoltan -
Hi,
where i can buy this replacement battery?
Thanks
Antanas Stankus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 9,518
