Giriş
Some users of the tablet have faced problems with their headphone jack. If the headphone jack is not working, this repair guide can be used to remove and replace it. Please note that this guide should be used if cleaning the headphone jack fails to resolve your audio problems.
It is important to note that this guide will involve soldering and desoldering. When soldering, make sure that you do not touch any metal parts of the soldering iron. It gets very hot, very quickly.
Neye ihtiyacın var
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using the soldering iron, detach the speaker's wires from the circuit board.
Desolder the six pins attaching the headphone jack to the motherboard
Remove headphone jack from motherboard
