Ana içeriğe geç
Nabi 2 Headphone Jack Replacement
Neye ihtiyacın var
  1. Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 1. Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 2. Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 3.
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Headphone Jack Replacement: adım 2, 2 resimden 1. Nabi 2 Headphone Jack Replacement: adım 2, 2 resimden 2.
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Headphone Jack Replacement: adım 3, 3 resimden 1. Nabi 2 Headphone Jack Replacement: adım 3, 3 resimden 2. Nabi 2 Headphone Jack Replacement: adım 3, 3 resimden 3.
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Headphone Jack Replacement, Screen: adım 4, 3 resimden 1. Nabi 2 Headphone Jack Replacement, Screen: adım 4, 3 resimden 2. Nabi 2 Headphone Jack Replacement, Screen: adım 4, 3 resimden 3.
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Headphone Jack Replacement: adım 5, 3 resimden 1. Nabi 2 Headphone Jack Replacement: adım 5, 3 resimden 2. Nabi 2 Headphone Jack Replacement: adım 5, 3 resimden 3.
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
  6. Nabi 2 Headphone Jack Replacement, Battery: adım 6, 3 resimden 1. Nabi 2 Headphone Jack Replacement, Battery: adım 6, 3 resimden 2. Nabi 2 Headphone Jack Replacement, Battery: adım 6, 3 resimden 3.
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Headphone Jack Replacement: adım 7, 3 resimden 1. Nabi 2 Headphone Jack Replacement: adım 7, 3 resimden 2. Nabi 2 Headphone Jack Replacement: adım 7, 3 resimden 3.
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Headphone Jack Replacement, Internal Speakers: adım 8, 1 resimden 1.
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Headphone Jack Replacement: adım 9, 3 resimden 1. Nabi 2 Headphone Jack Replacement: adım 9, 3 resimden 2. Nabi 2 Headphone Jack Replacement: adım 9, 3 resimden 3.
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Headphone Jack Replacement: adım 10, 1 resimden 1.
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Headphone Jack Replacement, Motherboard: adım 11, 2 resimden 1. Nabi 2 Headphone Jack Replacement, Motherboard: adım 11, 2 resimden 2.
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Headphone Jack Replacement: adım 12, 3 resimden 1. Nabi 2 Headphone Jack Replacement: adım 12, 3 resimden 2. Nabi 2 Headphone Jack Replacement: adım 12, 3 resimden 3.
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Headphone Jack Replacement: adım 13, 3 resimden 1. Nabi 2 Headphone Jack Replacement: adım 13, 3 resimden 2. Nabi 2 Headphone Jack Replacement: adım 13, 3 resimden 3.
    • Remove the motherboard by lifting from the area indicated
  14. Nabi 2 Headphone Jack Replacement, Headphone Jack: adım 14, 3 resimden 1. Nabi 2 Headphone Jack Replacement, Headphone Jack: adım 14, 3 resimden 2. Nabi 2 Headphone Jack Replacement, Headphone Jack: adım 14, 3 resimden 3.
    • Desolder the six pins attaching the headphone jack to the motherboard
    • Remove headphone jack from motherboard
Sonuç
Amy
285 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Lacy Spring 2016 USF Tampa, Team 4-3, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,248
