Ana içeriğe geç
Nabi 2 Heat Sink Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Nabi 2 Heat Sink Replacement, Open the device: adım 1, 1 resimden 1.
    • Remove all the screws and place them on a magnet. This will keep them from rolling away and becoming lost.
    FixBot'a Sor
    Yorum Ekle
  2. Nabi 2 Heat Sink Replacement: adım 2, 1 resimden 1.
    • Insert a flat-edge and attempt to gently pry the covers apart. If you pry them too roughly, they may crack and break. (DO NOT have a magnet near the tablet when you open it. This will destroy all files and programs on your tablet, making it useless.)
    FixBot'a Sor
    Yorum Ekle
  3. Nabi 2 Heat Sink Replacement, Look for Heat Sink: adım 3, 1 resimden 1.
    • Check to see if there is a large piece of metal tape over the battery. This is the heat sink. Its purpose is to disburse the heat away from the battery and hard drive, cooling the tablet and keeping it from overheating.
    • If the piece of tape is not there, and the tablet will not turn on, the tablet most likely shorted out.
    FixBot'a Sor
    Yorum Ekle
    • If the piece of tape is missing, you will need to purchase the appropriate metal tape. This can be found online.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
lauryn
215 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,486
