Ana içeriğe geç
Nabi 2 Internal Speakers Replacement
Neye ihtiyacın var
  1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 2. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 3.
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Internal Speakers Replacement: adım 2, 2 resimden 1. Nabi 2 Internal Speakers Replacement: adım 2, 2 resimden 2.
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Internal Speakers Replacement: adım 3, 3 resimden 1. Nabi 2 Internal Speakers Replacement: adım 3, 3 resimden 2. Nabi 2 Internal Speakers Replacement: adım 3, 3 resimden 3.
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Internal Speakers Replacement, Internal Speakers: adım 4, 1 resimden 1.
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  5. Nabi 2 Internal Speakers Replacement: adım 5, 3 resimden 1. Nabi 2 Internal Speakers Replacement: adım 5, 3 resimden 2. Nabi 2 Internal Speakers Replacement: adım 5, 3 resimden 3.
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  6. Nabi 2 Internal Speakers Replacement: adım 6, 1 resimden 1.
    • Once the screws have been removed, remove the speakers from the device.
Sonuç
Michelle
851 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Lacy Spring 2016 USF Tampa, Team 4-3, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 729
