Giriş
This guide will aid you in the process of removing the camera of the device. This is useful in replacing a broken or dis-functioning camera.
Neye ihtiyacın var
Make sure the screen is facing away from you and the back cover is facing you.
Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the ten 4mm screws in a counter-clockwise rotation.
2 farklı kişi bu kılavuzu tamamladı.
