Ana içeriğe geç
Nabi 2S Disassembly
Neye ihtiyacın var
  1. Nabi 2S Disassembly, Nabi 2S Disassembly: adım 1, 1 resimden 1.
    • Remove the red rubber case from the device.
  2. Nabi 2S Disassembly: adım 2, 2 resimden 1. Nabi 2S Disassembly: adım 2, 2 resimden 2.
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Disassembly: adım 3, 1 resimden 1.
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Disassembly: adım 4, 1 resimden 1.
    • After the back case is loosened, remove it from the device to change or access the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Riana Ramirez
680 İtibar
4 adet Kılavuz yazıldı
Ekip
Marist, Team 1-4, Laflen Spring 2016 Marist, Team 1-4, Laflen Spring 2016 üyesi
MARS-LAFLEN-S16S1G4
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 573
