Ana içeriğe geç
Nabi Big Tab HD24 Charging Port Replacement
Neye ihtiyacın var
  1. Nabi Big Tab HD24  Charging  Port Replacement, Back Assembly: adım 1, 1 resimden 1.
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
  2. Nabi Big Tab HD24  Charging  Port Replacement: adım 2, 1 resimden 1.
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
  3. Nabi Big Tab HD24  Charging  Port Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
  4. Nabi Big Tab HD24  Charging  Port Replacement: adım 4, 1 resimden 1.
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
  5. Nabi Big Tab HD24  Charging  Port Replacement: adım 5, 1 resimden 1.
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
  6. Nabi Big Tab HD24  Charging  Port Replacement: adım 6, 2 resimden 1. Nabi Big Tab HD24  Charging  Port Replacement: adım 6, 2 resimden 2.
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
  7. Nabi Big Tab HD24  Charging  Port Replacement: adım 7, 2 resimden 1. Nabi Big Tab HD24  Charging  Port Replacement: adım 7, 2 resimden 2.
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
  8. Nabi Big Tab HD24  Charging  Port Replacement: adım 8, 1 resimden 1.
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
  9. Nabi Big Tab HD24  Charging  Port Replacement: adım 9, 1 resimden 1.
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
  10. Nabi Big Tab HD24  Charging  Port Replacement: adım 10, 1 resimden 1.
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
  11. Nabi Big Tab HD24  Charging  Port Replacement: adım 11, 1 resimden 1.
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
  12. Nabi Big Tab HD24  Charging  Port Replacement: adım 12, 2 resimden 1. Nabi Big Tab HD24  Charging  Port Replacement: adım 12, 2 resimden 2.
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
  13. Nabi Big Tab HD24  Charging  Port Replacement, Battery Charging Port: adım 13, 2 resimden 1. Nabi Big Tab HD24  Charging  Port Replacement, Battery Charging Port: adım 13, 2 resimden 2.
    • Locate the battery charging port labeled "DC" on the side of the tablet .
  14. Nabi Big Tab HD24  Charging  Port Replacement: adım 14, 2 resimden 1. Nabi Big Tab HD24  Charging  Port Replacement: adım 14, 2 resimden 2.
    • Use a Philips #1 screw driver to unscrew the two silver 4.5 mm screws located on top of the circuit board.
  15. Nabi Big Tab HD24  Charging  Port Replacement: adım 15, 1 resimden 1.
    • Disconnect the white port with black and red cables from the circuit board with your hands.
    • It may take a few tries to remove the cable, since it is connected very tightly. Wiggling it some may help.
    • Replace your circuit board with the new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Karen Lopez
125 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Livingston Fall 2016 Cal Poly, Team 4-1, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G1
4 Üyeler
14 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi! Awesome! One question. Where do I get a new charging circuit board? Thanks!
Gordon Unitas - Yanıt Paylaş
Hi, have Nabi tablet, did you know where can I get the charging circuit board. T Q
David Marzll - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 3,239
