Giriş
Make sure you are using the correct charging cable. Use the black cable, since the white cable can only be used for data transfer. Do not confuse the audio port with DC port. Test the power cable and nabi power adapter separately before attempting to fix DC port. If non of the above are causing the problem, replace the DC port.
Locate the battery charging port labeled "DC" on the side of the tablet .
Bir başkası bu kılavuzu tamamladı.
One Comment
Hi! Awesome! One question. Where do I get a new charging circuit board? Thanks!
