Ana içeriğe geç
Nabi Big Tab HD24 Speakers Replacement
Neye ihtiyacın var
  1. Nabi Big Tab HD24 Speakers Replacement, Back Assembly: adım 1, 1 resimden 1.
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
  2. Nabi Big Tab HD24 Speakers Replacement: adım 2, 1 resimden 1.
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
  3. Nabi Big Tab HD24 Speakers Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
  4. Nabi Big Tab HD24 Speakers Replacement: adım 4, 1 resimden 1.
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
  5. Nabi Big Tab HD24 Speakers Replacement: adım 5, 1 resimden 1.
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
  6. Nabi Big Tab HD24 Speakers Replacement: adım 6, 2 resimden 1. Nabi Big Tab HD24 Speakers Replacement: adım 6, 2 resimden 2.
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
  7. Nabi Big Tab HD24 Speakers Replacement: adım 7, 2 resimden 1. Nabi Big Tab HD24 Speakers Replacement: adım 7, 2 resimden 2.
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
  8. Nabi Big Tab HD24 Speakers Replacement: adım 8, 1 resimden 1.
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
  9. Nabi Big Tab HD24 Speakers Replacement: adım 9, 1 resimden 1.
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
  10. Nabi Big Tab HD24 Speakers Replacement: adım 10, 1 resimden 1.
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
  11. Nabi Big Tab HD24 Speakers Replacement: adım 11, 1 resimden 1.
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
  12. Nabi Big Tab HD24 Speakers Replacement: adım 12, 2 resimden 1. Nabi Big Tab HD24 Speakers Replacement: adım 12, 2 resimden 2.
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
  13. Nabi Big Tab HD24 Speakers Replacement, Speakers: adım 13, 1 resimden 1.
    • Locate the faulty speaker. The two speakers are located in the upper corners of the back panel.
  14. Nabi Big Tab HD24 Speakers Replacement: adım 14, 1 resimden 1.
    • Lift the speakers upwards, out of its holding place, with your fingers.
    • Lift from the cross shaped white plastic surrounded by the speakers at its edges.
  15. Nabi Big Tab HD24 Speakers Replacement: adım 15, 1 resimden 1.
    • Remove the black tape taping the two wire bundles together.
    • Follow the wires attached to the speakers to the motherboard.
    • Gently lift up the aluminum tape so you can see the white connector connecting the wires to the motherboard.
  16. Nabi Big Tab HD24 Speakers Replacement: adım 16, 2 resimden 1. Nabi Big Tab HD24 Speakers Replacement: adım 16, 2 resimden 2.
    • Pull the wire bundle out of the motherboard with a light tug to disconnect the speakers.
    • Replace your broken speaker with the new ones.
Sonuç
Kevin Garcia
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Livingston Fall 2016 Cal Poly, Team 4-1, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G1
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 284
