Ana içeriğe geç
Nabi DreamTab HD8 Front Panel Assembly Replacement
Neye ihtiyacın var
    1. Nabi DreamTab HD8 Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 2 resimden 1. Nabi DreamTab HD8 Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 2 resimden 2.
      • Position the Nabi DreamTab onto a non-metallic surface so that the screen is facing towards the ceiling, and the DreamTab logo appears closest to you.
      • Remove the red silicone case from the Nabi DreamTab HD8.
      • These steps are specific to the included manufacturer case. If you have a different protective case, please refer to the respective manual for removal.
      FixBot'a Sor
      Yorum Ekle
    2. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 2, 1 resimden 1.
      • Turn it upside down, ensuring the small black circular camera is in the upper left hand corner.
      • Proceeding beyond here will void the manufacturer's warranty. If you wish to continue, follow these steps carefully.
      FixBot'a Sor
      Yorum Ekle
    3. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 3, 2 resimden 1. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 3, 2 resimden 2.
      • Remove the six 2.5 mm JIS #000 screws attaching the custom grid to the back panel.
      FixBot'a Sor
      Yorum Ekle
    4. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 4, 2 resimden 1. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 4, 2 resimden 2.
      • Grasp one of the protruding squares and gently lift off the back plate. Place it aside for later reassembly.
      • This piece should come off very easily. If you have trouble removing it, all of the screws may not be completely removed. Check and proceed.
      • Do not confuse the golden threads for screws.
      FixBot'a Sor
      Yorum Ekle
    5. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 5, 3 resimden 1. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 5, 3 resimden 2. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 5, 3 resimden 3.
      • Remove the three 3.5mm screws using the J-0 screwdriver attaching the back panel to the device.
      FixBot'a Sor
      Yorum Ekle
    6. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 6, 3 resimden 1. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 6, 3 resimden 2. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 6, 3 resimden 3.
      • Rotate the top of the device towards you so that the audio jack appears on the right side of the device.
      • The audio jack will have a small symbol of headphones next to a small 3.5mm diameter hole.
      • Wedge the plastic opening tool between where the front and back case panels meet near the audio jack.
      • Pry the device open using moderate force until you hear a clicking sound. This is the sound of the clips unlocking.
      • Move along the perimeter of the entire device using the same prying motion to gradually separate the front and back panels.
      • Once the edges are open return to the same starting position next to the audio jack.
      • During this step, you may crack some parts of the case. Gently pry around the speakers, audio jack and charging cable ports to reduce this damage.
      FixBot'a Sor
      Yorum Ekle
    7. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 7, 3 resimden 1. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 7, 3 resimden 2. Nabi DreamTab HD8 Front Panel Assembly Replacement: adım 7, 3 resimden 3.
      • Once you've completed separating the front and back panels, place the device back onto the table, display facing downward and camera at the top left.
      • Lift off the back panel and rotate the device 180 degrees while the screen is facing down.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ruby
158 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-3, Bruce Fall 2015 CSU Fullerton, Team 2-3, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G3
4 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
What is this exactly showing? The topic is "Front Panel Assembly Replacement" but all it shows is how to take it apart. Am I missing a step after Step 7?
Albert - Yanıt Paylaş
In the old IN08A Dreamtab, you could remove the touch screen with a heat gun and patient , but the LCD was attached to the Top glass via a soldered cable requiring both the Touchscreen and LCD to be bought together.
The NV08B, The Touchscreen is separate from the LCD screen. However, the Touchscreen at least on my NV08B that I tried to remove was glued down inherent much tougher and a heat gun wouldn’t loosen the glue around the sides of the LCD making it pretty much irreplaceable. I suppose a good glue solvent may have helped there, but I was lazy to purchase one. In the case you are better than me and able to remove the glass, I would recommend removing the LCD screen completely which is attached to the metal plate containing most of the components. (I also damaged the LCD while trying to pry the touchscreen out which I found out later.) I had to replace by purchasing the case/Touchscreen/Case for ~$30 and moving the components from the broken Nabi to the good touchscreen Nabi and that was much easier.
Lawrence - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 2,744
