Ana içeriğe geç
Nabi Jr Battery Replacement
Neye ihtiyacın var
    1. Nabi Jr Battery Replacement, Rear Case: adım 1, 1 resimden 1.
      • Remove the red rubber case from the device. This should come off with ease.
      FixBot'a Sor
      Yorum Ekle
    2. Nabi Jr Battery Replacement: adım 2, 1 resimden 1.
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      FixBot'a Sor
      Yorum Ekle
    3. Nabi Jr Battery Replacement: adım 3, 1 resimden 1.
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      FixBot'a Sor
      Yorum Ekle
    4. Nabi Jr Battery Replacement: adım 4, 1 resimden 1.
      • After loosening the back cover, remove it from the device so you can get at the innards.
      FixBot'a Sor
      Yorum Ekle
    1. Nabi Jr Battery Replacement, Battery: adım 5, 1 resimden 1.
      • Lift the battery up from the motherboard.
      • Don't rip the soldered wires from the board.
      • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
      FixBot'a Sor
      Yorum Ekle
    2. Nabi Jr Battery Replacement: adım 6, 1 resimden 1.
      • Remove the battery from the motherboard
      • De-solder the colored wires
      • Be sure to note the order in which the wires are connected to the board before desoldering them.
      • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
      FixBot'a Sor
      Yorum Ekle
    3. Nabi Jr Battery Replacement: adım 7, 2 resimden 1. Nabi Jr Battery Replacement: adım 7, 2 resimden 2.
      • Replace the old battery with the new one
      • Solder the wires of the new battery into the pads on the motherboard
      • Be careful when soldering the wires in. Soldering iron will be extremely hot
      FixBot'a Sor
      Yorum Ekle
    4. Nabi Jr Battery Replacement: adım 8, 1 resimden 1.
      • Once the wires are fully soldered, put the new battery back to the initial position
      • Close the case by putting the back cover back on the device
      • Will take some force
      • Make sure the battery is not in the way of the back cover
      FixBot'a Sor
      Yorum Ekle
    5. Nabi Jr Battery Replacement: adım 9, 1 resimden 1.
      • Once the back cover is on, screw in the four screws that you had taken off in the beginning
      • Put the red rubber casing back on.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If all the steps were followed correctly, the device should be fully closed and ready to go
4 farklı kişi bu kılavuzu tamamladı.
Jimmy Nguyen
271 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
7Kılavuz Yorumları
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - Yanıt Paylaş
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow - Yanıt Paylaş
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - Yanıt Paylaş
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke - Yanıt Paylaş
Where can I buy the battery live in Mexico
Roos - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 12,350
