Ana içeriğe geç
Nabi Jr Motherboard Replacement
Neye ihtiyacın var
    1. Nabi Jr Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
      • Remove the red rubber case from the device. This should come off with ease.
      FixBot'a Sor
      Yorum Ekle
    2. Nabi Jr Motherboard Replacement: adım 2, 1 resimden 1.
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      FixBot'a Sor
      Yorum Ekle
    3. Nabi Jr Motherboard Replacement: adım 3, 1 resimden 1.
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      FixBot'a Sor
      Yorum Ekle
    4. Nabi Jr Motherboard Replacement: adım 4, 1 resimden 1.
      • After loosening the back cover, remove it from the device so you can get at the innards.
      FixBot'a Sor
      Yorum Ekle
    1. Nabi Jr Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
      • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
      FixBot'a Sor
      Yorum Ekle
    2. Nabi Jr Motherboard Replacement: adım 6, 1 resimden 1.
      • De-solder the grey wire from motherboard
      FixBot'a Sor
      Yorum Ekle
    3. Nabi Jr Motherboard Replacement: adım 7, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use tweezers to peel off all yellow tape from the motherboard
      • Yellow tape is used in all locations where there is ribbon cable present.
      FixBot'a Sor
      Yorum Ekle
    4. Nabi Jr Motherboard Replacement: adım 8, 2 resimden 1. Nabi Jr Motherboard Replacement: adım 8, 2 resimden 2.
      • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
      • Pull black locking tabs up in opposite direction of ribbon cable to remove.
      • Use tweezers to pull the ribbon cable out of the locking tab's slot
      FixBot'a Sor
      Yorum Ekle
    5. Nabi Jr Motherboard Replacement: adım 9, 2 resimden 1. Nabi Jr Motherboard Replacement: adım 9, 2 resimden 2.
      • Lift motherboard to separate it the from the case shell.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kaila Joy
86 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,439
