Ana içeriğe geç
Nabi Jr Rear Case Replacement
Neye ihtiyacın var
  1. Nabi Jr Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Rear Case Replacement: adım 2, 1 resimden 1.
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Rear Case Replacement: adım 3, 1 resimden 1.
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Rear Case Replacement: adım 4, 1 resimden 1.
    • After loosening the back cover, remove it from the device so you can get at the innards.
Sonuç
Tobias Young
27 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 399
