Ana içeriğe geç
Nabi Jr Speakers Replacement
Neye ihtiyacın var
  1. Nabi Jr Speakers Replacement, Rear Case: adım 1, 1 resimden 1.
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Speakers Replacement: adım 2, 1 resimden 1.
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Speakers Replacement: adım 3, 1 resimden 1.
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Speakers Replacement: adım 4, 1 resimden 1.
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    • The speakers are located near the top of the device close to the camera.
    • Using a desoldering tool, remove the speakers from the pads they are soldered to.
    • Note that the red wire is removed from the pad labeled with a "+" and the black wire comes from the pad labeled with a "-".
    • Solder the new speaker's wires onto their respective pads
Sonuç
Tobias Young
27 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 833
