Ana içeriğe geç
Nail Clipper Reassembly
  1. Nail Clipper Reassembly, Nail Clipper Reassembly: adım 1, 3 resimden 1. Nail Clipper Reassembly, Nail Clipper Reassembly: adım 1, 3 resimden 2. Nail Clipper Reassembly, Nail Clipper Reassembly: adım 1, 3 resimden 3.
    • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
    • The side of the rod with the notch should be inserted first.
    • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
    FixBot'a Sor
    Yorum Ekle
  2. Nail Clipper Reassembly: adım 2, 1 resimden 1.
    • Compress the body of the clippers to reveal the notch.
    FixBot'a Sor
    Yorum Ekle
  3. Nail Clipper Reassembly: adım 3, 1 resimden 1.
    • Rotate the rod until the notch opening faces away from the body.
    • This allows for easier completion of the following step.
    FixBot'a Sor
    Yorum Ekle
  4. Nail Clipper Reassembly: adım 4, 3 resimden 1. Nail Clipper Reassembly: adım 4, 3 resimden 2. Nail Clipper Reassembly: adım 4, 3 resimden 3.
    • Place the hole of the lever into the revealed rod notch.
    • Release the compressed nail clipper body to lock the lever into place.
    • Note: Position of the lever does not matter at this point.
    FixBot'a Sor
    Yorum Ekle
  5. Nail Clipper Reassembly: adım 5, 3 resimden 1. Nail Clipper Reassembly: adım 5, 3 resimden 2. Nail Clipper Reassembly: adım 5, 3 resimden 3.
    • Swivel the lever into its normal position, and test the nail clippers' functionality.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If you follow these steps, your nail clippers should be back to working order.
96 farklı kişi bu kılavuzu tamamladı.
Robert Weber
2.149 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G5
5 Üyeler
33 adet Kılavuz yazıldı
33Kılavuz Yorumları
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - Yanıt Paylaş
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - Yanıt Paylaş
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - Yanıt Paylaş
That's why it says reassembly 🤨
Blake Jordan-Borns - Yanıt Paylaş
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 53
Son 7 gün: 402
Son 30 gün: 1,761
Her zaman: 157,634
