Giriş
If your Nanit Pro N301 is not producing any sound or the sounds are dull, use this guide to replace the speaker. Some of the pieces are very small so make sure you have a tool that can grab tiny materials if you are unable to do so with your fingers. Make sure your device is not plugged in and connected to a power source during the repair.
Neye ihtiyacın var
Insert an opening pick into the seam between the front and rear case.
Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
Separate the front and rear case.
2 farklı kişi bu kılavuzu tamamladı.
