Giriş
JUMP Cable The World's first 2-in-1 cable + battery booster
JUMP doubles up as a charging cable and portable battery booster. An innovative combination that ensures you'll always have reserve power when you're on the go.
Neye ihtiyacın var
Start by extending/removing the cable so you can access the sides of the plastic body of the charger
With the 'top' LED side removed, and the cable extended, there is still a middle ring holding the case together. Lift it from the left side pictured, and carefully lift the right side of the cable from the plastic holder (that's part of the middle ring) to fully remove the middle ring section.
Note, you don't need to remove the middle, but I found it easier to access the batteries this way.
Second photo: close up of metal bracket and holder, on right in first photo.
Removing the middle ring removes the friction holding the power button in place. Mine fell out when I flipped the charger over. Re-insertion is easy by loosening the screws, and the button can only be inserted one way, indicated by a notch.
The batteries displayed prior to removal of the middle section.
I contacted Native Union for support identifying or sourcing the battery, but they indicated they were custom. I opted for 10280 batteries that are the same diameter and slightly shorter than the original.
Desolder and remove the original batteries.
Bir başkası bu kılavuzu tamamladı.
