Ana içeriğe geç
Neato BOTVAC CONNECTED Filter Replacement
Neye ihtiyacın var
  1. Neato BOTVAC CONNECTED Filter Replacement, Battery: adım 1, 1 resimden 1.
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Filter Replacement: adım 2, 2 resimden 1. Neato BOTVAC CONNECTED Filter Replacement: adım 2, 2 resimden 2.
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Filter Replacement: adım 3, 2 resimden 1. Neato BOTVAC CONNECTED Filter Replacement: adım 3, 2 resimden 2.
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Filter Replacement: adım 4, 3 resimden 1. Neato BOTVAC CONNECTED Filter Replacement: adım 4, 3 resimden 2. Neato BOTVAC CONNECTED Filter Replacement: adım 4, 3 resimden 3.
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Filter Replacement: adım 5, 1 resimden 1.
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Filter Replacement, Filter: adım 6, 1 resimden 1.
    • Flip the cleaner around and locate the front panel.
  7. Neato BOTVAC CONNECTED Filter Replacement: adım 7, 1 resimden 1.
    • Gently remove the front panel by opening it with a spudger.
  8. Neato BOTVAC CONNECTED Filter Replacement: adım 8, 2 resimden 1. Neato BOTVAC CONNECTED Filter Replacement: adım 8, 2 resimden 2.
    • Use the spudger to gently remove the paper filter.
Sonuç
Justin Silva
645 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2023 UMass Dartmouth, Team 6-3, Botvin Spring 2023 üyesi
UMASSD-BOTVIN-S23S6G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 74
