Ana içeriğe geç
Neato BOTVAC CONNECTED Front Roller Brush Replacement
Neye ihtiyacın var
  1. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Battery: adım 1, 1 resimden 1.
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 2, 2 resimden 1. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 2, 2 resimden 2.
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 3, 2 resimden 1. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 3, 2 resimden 2.
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 4, 3 resimden 1. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 4, 3 resimden 2. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 4, 3 resimden 3.
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 5, 1 resimden 1.
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: adım 6, 2 resimden 1. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: adım 6, 2 resimden 2.
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 7, 1 resimden 1.
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 8, 1 resimden 1.
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 9, 1 resimden 1.
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Front Roller Brush Replacement: adım 10, 1 resimden 1.
    • Gently remove the front brush.
Sonuç
Justin Silva
645 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2023 UMass Dartmouth, Team 6-3, Botvin Spring 2023 üyesi
UMASSD-BOTVIN-S23S6G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 119
