Giriş
If your robot is having battery trouble, or you want to disassemble the inner workings of your device, then you should remove, inspect, or even replace your battery if necessary. Leaving the battery in while working on your robot can lead to unnecessary danger.
Neye ihtiyacın var
Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
Unscrew the two 24 mm captive screws holding the battery compartment shut.
Neredeyse bitti!
Sonuç
