Giriş
This is a prerequisite guide to remove the rear bumper. Most repairs/ replacements will require you to remove the bumper and this guide will help you out.
Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
Bir başkası bu kılavuzu tamamladı.
pull the free bottom corners out a bit to free the catches
wilfried - Yanıt
