Ana içeriğe geç
Neato Botvac Connected Screen Replacement
Neye ihtiyacın var
  1. Neato Botvac Connected Screen Replacement, Screen: adım 1, 3 resimden 1. Neato Botvac Connected Screen Replacement, Screen: adım 1, 3 resimden 2. Neato Botvac Connected Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
    • Remove the four screws lining the front roller using a TR10 Torx screwdriver.
    • Remove the black panel behind and in front of the roller.
    • Gently lift the roller by the right side to remove it.
  2. Neato Botvac Connected Screen Replacement: adım 2, 1 resimden 1.
    • Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
    • Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
  3. Neato Botvac Connected Screen Replacement: adım 3, 3 resimden 1. Neato Botvac Connected Screen Replacement: adım 3, 3 resimden 2. Neato Botvac Connected Screen Replacement: adım 3, 3 resimden 3.
    • Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
  4. Neato Botvac Connected Screen Replacement: adım 4, 2 resimden 1. Neato Botvac Connected Screen Replacement: adım 4, 2 resimden 2.
    • Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
    • Remove the additional two TR10 screws from the top of the Botvac.
    • Remove the dustbin.
  5. Neato Botvac Connected Screen Replacement: adım 5, 3 resimden 1. Neato Botvac Connected Screen Replacement: adım 5, 3 resimden 2. Neato Botvac Connected Screen Replacement: adım 5, 3 resimden 3.
    • Pry the clips on the front of the robot apart.
    • Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
    • Make certain not to not to tear any wires out of the port.
    • Lay the top of the robot inside up.
  6. Neato Botvac Connected Screen Replacement: adım 6, 2 resimden 1. Neato Botvac Connected Screen Replacement: adım 6, 2 resimden 2.
    • Unplug the beige connector with a spudger. Be careful not to tear out any wires.
    • Remove the two screws from the screen using a TR10 Torx screwdriver.
    • Remove the screen from the vacuum.
Sonuç
Jerome
365 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 148
