Ana içeriğe geç
Neato Botvac D75 Battery Replacement
Neye ihtiyacın var
    1. Neato Botvac D75 Battery Replacement, Battery: adım 1, 3 resimden 1. Neato Botvac D75 Battery Replacement, Battery: adım 1, 3 resimden 2. Neato Botvac D75 Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
      • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
      FixBot'a Sor
      Yorum Ekle
    2. Neato Botvac D75 Battery Replacement: adım 2, 3 resimden 1. Neato Botvac D75 Battery Replacement: adım 2, 3 resimden 2. Neato Botvac D75 Battery Replacement: adım 2, 3 resimden 3.
      • Lift battery cover out.
      FixBot'a Sor
      Yorum Ekle
    3. Neato Botvac D75 Battery Replacement: adım 3, 3 resimden 1. Neato Botvac D75 Battery Replacement: adım 3, 3 resimden 2. Neato Botvac D75 Battery Replacement: adım 3, 3 resimden 3.
      • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
      • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Juan Cornejo
606 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G5, Lacy Spring 2017 USF Tampa, Team S6-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S6G5
4 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for the tuto.
an additionnal info when having a battery issue, is to the reset to new battery. enter the menu, then help, and chose new battery.
it seems the neato system is set for planned obsolescence… unfortunatly for customers….
so I did it because battery stayed empty while plugged and switch found ok . And new my botvac is ok, like new!!
Nom - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 2,996
