Ana içeriğe geç
Neato Botvac D8000 Brushes Replacement
Neye ihtiyacın var
  1. Neato Botvac D8000 Brushes Replacement, Brushes: adım 1, 1 resimden 1.
    • Place the vacuum on its back so the brushes are visible.
  2. Neato Botvac D8000 Brushes Replacement: adım 2, 3 resimden 1. Neato Botvac D8000 Brushes Replacement: adım 2, 3 resimden 2. Neato Botvac D8000 Brushes Replacement: adım 2, 3 resimden 3.
    • Remove the four 10 mm screws with a Torx T10 screwdriver.
  3. Neato Botvac D8000 Brushes Replacement: adım 3, 2 resimden 1. Neato Botvac D8000 Brushes Replacement: adım 3, 2 resimden 2.
    • Remove the rotary brush simply by grabbing it firmly and pulling it off.
    • Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
  4. Neato Botvac D8000 Brushes Replacement: adım 4, 2 resimden 1. Neato Botvac D8000 Brushes Replacement: adım 4, 2 resimden 2.
    • Remove the brush by simply pulling it out.
    • From there you can clean it or replace the brush with a new one.
Sonuç
Yeritza Quiroz
159 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 701
