Ana içeriğe geç
Neato Botvac D8000 Top Face Panel Replacement
Neye ihtiyacın var
  1. Neato Botvac D8000 Top Face Panel Replacement, Top Face Panel: adım 1, 1 resimden 1.
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac D8000 Top Face Panel Replacement: adım 2, 2 resimden 1. Neato Botvac D8000 Top Face Panel Replacement: adım 2, 2 resimden 2.
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  3. Neato Botvac D8000 Top Face Panel Replacement: adım 3, 2 resimden 1. Neato Botvac D8000 Top Face Panel Replacement: adım 3, 2 resimden 2.
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  4. Neato Botvac D8000 Top Face Panel Replacement: adım 4, 3 resimden 1. Neato Botvac D8000 Top Face Panel Replacement: adım 4, 3 resimden 2. Neato Botvac D8000 Top Face Panel Replacement: adım 4, 3 resimden 3.
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  5. Neato Botvac D8000 Top Face Panel Replacement: adım 5, 3 resimden 1. Neato Botvac D8000 Top Face Panel Replacement: adım 5, 3 resimden 2. Neato Botvac D8000 Top Face Panel Replacement: adım 5, 3 resimden 3.
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  6. Neato Botvac D8000 Top Face Panel Replacement: adım 6, 1 resimden 1.
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ruth Lopez
280 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 920
