Ana içeriğe geç
Neato Botvac D8000 Wheel Replacement
Neye ihtiyacın var
  1. Neato Botvac D8000 Wheel Replacement, Brushes: adım 1, 1 resimden 1.
    • Place the vacuum on its back so the brushes are visible.
  2. Neato Botvac D8000 Wheel Replacement: adım 2, 3 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 2, 3 resimden 2. Neato Botvac D8000 Wheel Replacement: adım 2, 3 resimden 3.
    • Remove the four 10 mm screws with a Torx T10 screwdriver.
  3. Neato Botvac D8000 Wheel Replacement: adım 3, 2 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 3, 2 resimden 2.
    • Remove the rotary brush simply by grabbing it firmly and pulling it off.
    • Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
  4. Neato Botvac D8000 Wheel Replacement: adım 4, 2 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 4, 2 resimden 2.
    • Remove the brush by simply pulling it out.
    • From there you can clean it or replace the brush with a new one.
  5. Neato Botvac D8000 Wheel Replacement, Top Face Panel: adım 5, 1 resimden 1.
    • Grab the rear bumper with both hands on either side.
  6. Neato Botvac D8000 Wheel Replacement: adım 6, 2 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 6, 2 resimden 2.
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  7. Neato Botvac D8000 Wheel Replacement: adım 7, 2 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 7, 2 resimden 2.
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  8. Neato Botvac D8000 Wheel Replacement: adım 8, 3 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 8, 3 resimden 2. Neato Botvac D8000 Wheel Replacement: adım 8, 3 resimden 3.
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  9. Neato Botvac D8000 Wheel Replacement: adım 9, 3 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 9, 3 resimden 2. Neato Botvac D8000 Wheel Replacement: adım 9, 3 resimden 3.
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  10. Neato Botvac D8000 Wheel Replacement: adım 10, 1 resimden 1.
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
  11. Neato Botvac D8000 Wheel Replacement, Wheel: adım 11, 3 resimden 1. Neato Botvac D8000 Wheel Replacement, Wheel: adım 11, 3 resimden 2. Neato Botvac D8000 Wheel Replacement, Wheel: adım 11, 3 resimden 3.
    • Locate the screws that mount the wheel extension to the Robot.
    • Unscrew the four 11mm screws indicated with a Torx T10 screwdriver to remove the frame.
    • Make sure to remove the metallic weight. However, this does not require the removal of any screws.
  12. Neato Botvac D8000 Wheel Replacement: adım 12, 3 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 12, 3 resimden 2. Neato Botvac D8000 Wheel Replacement: adım 12, 3 resimden 3.
    • Delicately lift up the frame holding the laser. This will access the wheels.
    • Detach the wheel wires that are connected to the motherboard.
    • Once the wires are detached, the wheel are free from their casing.
  13. Neato Botvac D8000 Wheel Replacement: adım 13, 2 resimden 1. Neato Botvac D8000 Wheel Replacement: adım 13, 2 resimden 2.
    • Use a Torx T15 screwdriver to remove the 32.5mm screw.
    • Finally, just hold and separate the wheel from its axle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ruth Lopez
280 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 3,519
