Ana içeriğe geç
Neato XV Signature Wheel Assembly Replacement
Neye ihtiyacın var
  1. Neato XV Signature Wheel Assembly Replacement, Wheel Assembly: adım 1, 1 resimden 1.
    • Place the Neato with the bottom side facing up.
  2. Neato XV Signature Wheel Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the four machine screws securing the main compartment plate using a Phillips #0 screwdriver.
  3. Neato XV Signature Wheel Assembly Replacement: adım 3, 2 resimden 1. Neato XV Signature Wheel Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the main compartment plate, exposing the wheel axis and fan.
  4. Neato XV Signature Wheel Assembly Replacement: adım 4, 1 resimden 1.
    • Lift up on the wheel axis to remove the axle bar from its clasp.
  5. Neato XV Signature Wheel Assembly Replacement: adım 5, 2 resimden 1. Neato XV Signature Wheel Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the axle bar from the wheel mount, exposing the suspension spring.
  6. Neato XV Signature Wheel Assembly Replacement: adım 6, 2 resimden 1. Neato XV Signature Wheel Assembly Replacement: adım 6, 2 resimden 2.
    • Unlatch the suspension spring from the wheel mount, exposing the wheel connector cable.
  7. Neato XV Signature Wheel Assembly Replacement: adım 7, 1 resimden 1.
    • Unplug the wheel connector cable.
    • Repeat steps 4-7 with the other wheel.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 192
