Ana içeriğe geç
Neato XV-21 Battery Replacement/Removal
Neye ihtiyacın var
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: adım 1, 1 resimden 1.
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: adım 2, 1 resimden 1.
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: adım 3, 1 resimden 1.
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: adım 4, 1 resimden 1.
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 1,195
