Giriş
This guide will help you disassemble your Neato XV-21 and replace the fan.
Neye ihtiyacın var
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
Once the wires are disconnected lift the fan from the cavity
3 farklı kişi bu kılavuzu tamamladı.
