Ana içeriğe geç
Neato XV-21 Wheels Replacement
Neye ihtiyacın var
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: adım 1, 1 resimden 1.
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: adım 2, 1 resimden 1.
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: adım 3, 1 resimden 1.
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: adım 4, 1 resimden 1.
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: adım 5, 1 resimden 1.
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: adım 6, 1 resimden 1.
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: adım 7, 2 resimden 1. Neato XV-21 Wheels Replacement: adım 7, 2 resimden 2.
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Needs to Link to Parts List and a way to Order Parts.
Bill Price - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 693
