Ana içeriğe geç
Necklace Barrel Clasp Repair
Neye ihtiyacın var
  1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: adım 1, 2 resimden 1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: adım 1, 2 resimden 2.
    • Locate the broken part of the ring that attaches through the back of the barrel clasp.
    • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
  2. Necklace Barrel Clasp Repair: adım 2, 1 resimden 1.
    • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
    • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
    • This method is not recommended for precious metals.
  3. Necklace Barrel Clasp Repair: adım 3, 1 resimden 1.
    • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
    • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
    • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
  4. Necklace Barrel Clasp Repair: adım 4, 1 resimden 1.
    • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
    • Do not pull too hard—the amount of strain may cause the solder to break.
Sonuç
Garrett Key
110 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S1-G5, Rauch Summer 2017 Texas Tech, Team S1-G5, Rauch Summer 2017 üyesi
TTU-RAUCH-SU17S1G5
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,911
