Giriş
The guide is the beginning of every other guide for the Neo3DO device. In order to access any of the other parts for repair or replacement, you need to remove the back panel. DO NOT attempt to remove the front screen, as it is part of the device case and removing it will damage the tablet.
Check all other guides you plan to follow and have all tools laid out in advance. Make sure your workspace is clean and clear of anything not needed for the replacement.
Neye ihtiyacın var
Turn the Neo3DO face down so that the logo is facing toward you.
Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
