Ana içeriğe geç
Neo3Do Wire Replacement
Neye ihtiyacın var
  1. Neo3Do Wire Replacement, Back Panel: adım 1, 3 resimden 1. Neo3Do Wire Replacement, Back Panel: adım 1, 3 resimden 2. Neo3Do Wire Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
    FixBot'a Sor
    Yorum Ekle
  2. Neo3Do Wire Replacement: adım 2, 2 resimden 1. Neo3Do Wire Replacement: adım 2, 2 resimden 2.
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
    FixBot'a Sor
    Yorum Ekle
  3. Neo3Do Wire Replacement: adım 3, 2 resimden 1. Neo3Do Wire Replacement: adım 3, 2 resimden 2.
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
    FixBot'a Sor
    Yorum Ekle
  4. Neo3Do Wire Replacement: adım 4, 1 resimden 1.
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
    FixBot'a Sor
    Yorum Ekle
  5. Neo3Do Wire Replacement, Wire: adım 5, 3 resimden 1. Neo3Do Wire Replacement, Wire: adım 5, 3 resimden 2. Neo3Do Wire Replacement, Wire: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Starting with an open back panel, take your tweezers and use them to pull back the black tabs on the connector.
    FixBot'a Sor
    Yorum Ekle
  6. Neo3Do Wire Replacement: adım 6, 1 resimden 1.
    • Pull the wire completely from the socket.
    • Check the metallic parts for signs of damage or corrosion. If either exists, you might need to replace the battery entirely.
    FixBot'a Sor
    Yorum Ekle
  7. Neo3Do Wire Replacement: adım 7, 1 resimden 1.
    • Re-insert the wire into the socket.
    FixBot'a Sor
    Yorum Ekle
  8. Neo3Do Wire Replacement: adım 8, 3 resimden 1. Neo3Do Wire Replacement: adım 8, 3 resimden 2. Neo3Do Wire Replacement: adım 8, 3 resimden 3.
    • Using the tweezers, push the black tabs back in.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Whitehead
201 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-3, Eyestone Fall 2016 USF Tampa, Team 14-3, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 401
