Giriş
This guide will walk you through the steps to disassemble your Nerf rifle and access the hammer rod. After you have replaced the rod you will simply follow the guide in reverse to get back to the the action!
Neye ihtiyacın var
Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
Bir başkası bu kılavuzu tamamladı.
