Giriş
A broken plunger may inhibit your gun from firing correctly. This guide will show you how to replace the plunger and return your riffle to firing condition.
Neye ihtiyacın var
Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
Bir başkası bu kılavuzu tamamladı.
