Ana içeriğe geç
Nerf Alpha Trooper CS-18 Plunger Replacement
Neye ihtiyacın var
  1. Nerf Alpha Trooper CS-18 Plunger Replacement, Plunger: adım 1, 1 resimden 1.
    • It is important to group screws together by length to ensure proper reassembly.
    • Be sure that the device has been discharged and is unloaded before beginning the repair process.
  2. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 2, 3 resimden 1. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 2, 3 resimden 2. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 2, 3 resimden 3.
    • Look at the rear of the rifle. Remove the two 10 mm Phillips head screws that hold the black cap to the rear of the rifle.
    • Gently remove the black cap.
  3. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 3, 2 resimden 1. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 3, 2 resimden 2.
    • Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
    • Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
    • Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
    • Be sure to keep track of which screws correspond to the correct holes.
  4. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 4, 3 resimden 1. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 4, 3 resimden 2. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 4, 3 resimden 3.
    • Keeping the barrel in the same position as step 3, remove the fourteen 10 mm Phillips head screws from the body of the device.
    • With the device in the same position, remove the 4 remaining 5 mm Phillips head screws from the body of the device.
    • Screws vary in lengths. Be sure to keep track of which screws correspond to the correct holes.
  5. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 5, 3 resimden 1. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 5, 3 resimden 2. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 5, 3 resimden 3.
    • Grip the cartridge insert, and pull the two halves of the device apart.
    • Warning! The firing spring is not fastened to the device. It and other small parts may fall out of the device when separating it.
    • If you are having difficulty separating the two halves of the device, use a spudger to pry the two halves apart.
    • Remove the access gate and barrel cover.
  6. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 6, 1 resimden 1.
    • Now remove the main firing spring from the rear of the device by gently pulling it.
  7. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 7, 2 resimden 1. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 7, 2 resimden 2.
    • Slide the plunger lock back away from the device, then lift out towards yourself to remove.
    • Be careful not to lose the small spring on the top of the plunger lock.
  8. Nerf Alpha Trooper CS-18 Plunger Replacement: adım 8, 1 resimden 1.
    • Pull plunger away in the same motion as in step 7 with the plunger lock.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,892
