Ana içeriğe geç
Nerf Dart Tag Furyfire Large Spring Replacement
Neye ihtiyacın var
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: adım 2, 1 resimden 1.
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: adım 3, 1 resimden 1.
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: adım 4, 2 resimden 1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: adım 4, 2 resimden 2.
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Sonuç
Bradley Penrow
37 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,439
