Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
In this guide, you will be able to easily find and replace the trigger spring for the Nerf Dart Tag Swarmfire.
Parçalar
Hiçbir parça belirtilmedi.
  1. Place the Nerf gun on its side and loosen all nine screws  so the device can be opened. Avoid the fake plastic screw, which is merely decorative.
    • Place the Nerf gun on its side and loosen all nine screws so the device can be opened.
    • Avoid the fake plastic screw, which is merely decorative.
  2. Remove the yellow and blue plastic covers from the Nerf gun to display the Nerf gun's motherboards and motor. Remove the yellow and blue plastic covers from the Nerf gun to display the Nerf gun's motherboards and motor. Remove the yellow and blue plastic covers from the Nerf gun to display the Nerf gun's motherboards and motor.
    • Remove the yellow and blue plastic covers from the Nerf gun to display the Nerf gun's motherboards and motor.
  3. Locate the orange trigger (dark blue if it's the newer version). Slide trigger out of place and check the spring. It's important to check the spring for damage before removing the spring to prevent injuries.
    • Locate the orange trigger (dark blue if it's the newer version).
    • Slide trigger out of place and check the spring.
    • It's important to check the spring for damage before removing the spring to prevent injuries.
  4. If it is damaged, pull the spring off the trigger. Push the new trigger spring onto the trigger
    • If it is damaged, pull the spring off the trigger.
    • Push the new trigger spring onto the trigger
    • Make sure the trigger catches the small trigger notch so it doesn't fall off
  5. Put the trigger back into place with the trigger spring pressed into the small compartment. Put the trigger back into place with the trigger spring pressed into the small compartment. Put the trigger back into place with the trigger spring pressed into the small compartment.
    • Put the trigger back into place with the trigger spring pressed into the small compartment.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashely Janae Wodall
242 İtibar
2 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 431
