Ana içeriğe geç
Nerf Mega Magnus Spring Replacement
Neye ihtiyacın var
  1. Nerf Mega Magnus Spring Replacement, Spring: adım 1, 3 resimden 1. Nerf Mega Magnus Spring Replacement, Spring: adım 1, 3 resimden 2. Nerf Mega Magnus Spring Replacement, Spring: adım 1, 3 resimden 3.
    • Start by removing the (4) exterior Phillips screws from the shell of the gun with a #1 Phillips Screwdriver.
  2. Nerf Mega Magnus Spring Replacement: adım 2, 2 resimden 1. Nerf Mega Magnus Spring Replacement: adım 2, 2 resimden 2.
    • Pulling upward from the rest of the shell, carefully remove the half of the slide facing you.
  3. Nerf Mega Magnus Spring Replacement: adım 3, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 3, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 3, 3 resimden 3.
    • On the same side, remove all (9) screws from the body of the blaster as shown.
  4. Nerf Mega Magnus Spring Replacement: adım 4, 2 resimden 1. Nerf Mega Magnus Spring Replacement: adım 4, 2 resimden 2.
    • Lift up on the top half of the shell with deliberate force. This should reveal the internals.
  5. Nerf Mega Magnus Spring Replacement: adım 5, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 5, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 5, 3 resimden 3.
    • Remove the screws from the trigger mechanism and lift it upward
  6. Nerf Mega Magnus Spring Replacement: adım 6, 2 resimden 1. Nerf Mega Magnus Spring Replacement: adım 6, 2 resimden 2.
    • Locate the small grey piece under the plunger tube and remove the screw.
  7. Nerf Mega Magnus Spring Replacement: adım 7, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 7, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 7, 3 resimden 3.
    • Locate the screws on the return spring. Using a counterclockwise rotation, remove both of the screws.
  8. Nerf Mega Magnus Spring Replacement: adım 8, 2 resimden 1. Nerf Mega Magnus Spring Replacement: adım 8, 2 resimden 2.
    • Using a small tool, carefully remove the spring from its pegs.
  9. Nerf Mega Magnus Spring Replacement: adım 9, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 9, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 9, 3 resimden 3.
    • Locate the screws behind the dart pusher mechanism. Carefully remove each screw.
  10. Nerf Mega Magnus Spring Replacement: adım 10, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 10, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 10, 3 resimden 3.
    • Pull upwards on the dart pusher and spring to remove them.
  11. Nerf Mega Magnus Spring Replacement: adım 11, 2 resimden 1. Nerf Mega Magnus Spring Replacement: adım 11, 2 resimden 2.
    • Lift up on the magazine plate in order to remove it.
  12. Nerf Mega Magnus Spring Replacement: adım 12, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 12, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 12, 3 resimden 3.
    • Pull upward on the dart lip and it will lift off.
  13. Nerf Mega Magnus Spring Replacement: adım 13, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 13, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 13, 3 resimden 3.
    • Lift the left side of the plunger tube from its peg and the rest will slide off the spring peg.
  14. Nerf Mega Magnus Spring Replacement: adım 14, 3 resimden 1. Nerf Mega Magnus Spring Replacement: adım 14, 3 resimden 2. Nerf Mega Magnus Spring Replacement: adım 14, 3 resimden 3.
    • Slide the spring off its peg. If the spring is damaged, replace it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 3,570
