Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Be sure that the rifle is discharged and unloaded before starting disassembly.
Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Separate and remove the two halves of the slide mechanism.
Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
Remove the two 5 mm phillips screws from the main body.
Remove the two 8 mm phillips screws from the main body.
Pull the two halves of the rifle apart.
Remove the access gate and barrel cover.
You should now be able to pull the main firing spring from the rear of the rifle.
2 farklı kişi bu kılavuzu tamamladı.
