Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Be sure that the rifle is discharged and unloaded before starting disassembly.
Looking at the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Remove the two halves of the slide mechanism.
Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
Remove the two 5mm phillips screws from the main body.
Remove the two 8 mm phillips screws from the main body.
Pull the two halves of the rifle apart.
Remove the access gate and barrel cover.
Remove the single 8mm phillips screw holding the trigger mechanism is place.
Remove the trigger mechanism.
Remove the small spring from the rear of the mechanism and replace it with a new spring.
2 farklı kişi bu kılavuzu tamamladı.
