Ana içeriğe geç
Nerf N-Strike Elite Hail-Fire Battery Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: adım 2, 1 resimden 1.
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: adım 3, 1 resimden 1.
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: adım 4, 1 resimden 1.
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: adım 5, 1 resimden 1.
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jonathan Peck
217 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G13
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
thanks it works
unturned lore - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 91
Her zaman: 25,700
