Ana içeriğe geç
Nerf N-Strike Elite Hail-Fire Trigger Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: adım 1, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: adım 1, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: adım 1, 3 resimden 3.
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 2, 1 resimden 1.
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 3, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 3, 2 resimden 2.
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 4, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 4, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 4, 3 resimden 3.
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 5, 1 resimden 1.
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 6, 1 resimden 1.
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 7, 1 resimden 1.
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 8, 1 resimden 1.
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 9, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 9, 2 resimden 2.
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 10, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 10, 2 resimden 2.
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 11, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 11, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 11, 3 resimden 3.
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 12, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 12, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 12, 3 resimden 3.
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
  13. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: adım 13, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: adım 13, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: adım 13, 3 resimden 3.
    • Remove the cartridge support.
  14. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 14, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 14, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 14, 3 resimden 3.
    • Remove the handle crank.
  15. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 15, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 15, 2 resimden 2.
    • Remove the clear plastic barrel cover.
  16. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 16, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 16, 2 resimden 2.
    • Remove the firing pin.
  17. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Right Shell: adım 17, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Right Shell: adım 17, 2 resimden 2.
    • Lift the trigger mechanism out of the shell.
    • You cannot fully remove the trigger mechanism just yet. However taking it out of the shell helps in later steps.
  18. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 18, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 18, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 18, 3 resimden 3.
    • Remove the two 9.0 mm Phillips screws.
  19. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 19, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 19, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 19, 3 resimden 3.
    • To remove the motor and trigger mechanism you have to detach these two wires which are glued to the shell.
    • Hold close to the wire and pull upward slowly.
    • If you pull too quickly you can potentially damage the wire.
  20. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 20, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 20, 2 resimden 2.
    • Once all the pieces are removed the right shell should be fully accessible.
  21. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: adım 21, 3 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: adım 21, 3 resimden 2. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: adım 21, 3 resimden 3.
    • Remove the single 9.0 mm Phillips screw.
  22. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 22, 2 resimden 1. Nerf N-Strike Elite Hail-Fire Trigger Replacement: adım 22, 2 resimden 2.
    • Locate the orange bar protruding from the rest of the gun. You should see the spring hooked onto two ends.
    • Push the orange bar until the spring becomes loose.
    • The trigger should come loose right away.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris
273 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G13
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 2,402
