Ana içeriğe geç
Nerf N-Strike Elite Retaliator Barrel Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: adım 1, 1 resimden 1.
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
    FixBot'a Sor
    Yorum Ekle
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: adım 2, 1 resimden 1.
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
    FixBot'a Sor
    Yorum Ekle
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: adım 3, 1 resimden 1.
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: adım 4, 1 resimden 1.
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
    FixBot'a Sor
    Yorum Ekle
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: adım 5, 1 resimden 1.
    • Remove the orange barrel from the assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
ericharman
1.440 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 12,413
