Giriş
A damaged or obstructed barrel can greatly hinder your blaster’s performance. Follow the procedure to clean or replace the barrel.
Modifying your blaster is not advised and may void the manufacturer’s warranty in certain states.
This blaster is equipped with a rifled barrel for maximum performance.
Neye ihtiyacın var
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
Disassemble the orange barrel cap by removing two 8mm Phillips screws.
Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
6 farklı kişi bu kılavuzu tamamladı.
