Ana içeriğe geç
Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: adım 1, 1 resimden 1.
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 4, 2 resimden 1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 5, 2 resimden 1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: adım 6, 1 resimden 1.
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 7, 1 resimden 1.
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 8, 1 resimden 1.
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
ericharman
1.410 İtibar
5 adet Kılavuz yazıldı
4 Yorum
Where did we found the pièces??
Albert Einstein - Yanıt
where i can buy for spare part “air chamber”?
sabeni83_king - Yanıt
this tutorial helped A LOT
Daniel MacDonald - Yanıt
OK I've removed the air chamber now what?
camper234 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 60
Her zaman: 19,983
