Ana içeriğe geç
Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: adım 1, 1 resimden 1.
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
    What about a drum mag how do you remove that
    Alex Leadbeater - Yanıt
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 4, 2 resimden 1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 5, 2 resimden 1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
    Itd be nice if we got a pic comparing the internals to an old yellow nerf recon (if you have one). I wonder how much changes between generations.
    sigoshi - Yanıt
    Removed every screw and gun does not separate. not showing the seperation of the gun makes this tutorial completely useless.
    Jeff Glover - Yanıt
    You have to remove the thing you use to ready it
    Daniel MacDonald -
    It would be nice if you could color-code where to put the 16mm, 10mm and 8mm screws. That way, you don’t wind up damaging the screw post or stripping a screw by trying to insert a 10mm screw into a post meant for an 8mm one.
    SirMikay - Yanıt
    it's very helpful that the troubleshooting for slider won't move backwards goes to "Another two must be removed with the sliding mechanism in the back position." How, just how do you do that if it's jammed
    Adrian Tennies - Yanıt
    please help if you can
    Adrian Tennies -
    definitely not angry at the troubleshooting page
    Adrian Tennies -
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: adım 6, 1 resimden 1.
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 7, 1 resimden 1.
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: adım 8, 1 resimden 1.
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
ericharman
1.410 İtibar
5 adet Kılavuz yazıldı
4 Yorum
Where did we found the pièces??
Albert Einstein - Yanıt
where i can buy for spare part “air chamber”?
sabeni83_king - Yanıt
this tutorial helped A LOT
Daniel MacDonald - Yanıt
OK I've removed the air chamber now what?
camper234 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 57
Her zaman: 19,952
