Ana içeriğe geç
Nerf N-Strike Elite Retaliator Spring Replacement
Neye ihtiyacın var
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: adım 1, 1 resimden 1.
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: adım 2, 1 resimden 1.
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: adım 3, 1 resimden 1.
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: adım 4, 2 resimden 1. Nerf N-Strike Elite Retaliator Spring Replacement: adım 4, 2 resimden 2.
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: adım 5, 2 resimden 1. Nerf N-Strike Elite Retaliator Spring Replacement: adım 5, 2 resimden 2.
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: adım 6, 2 resimden 1. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: adım 6, 2 resimden 2.
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
ericharman
1.410 İtibar
5 adet Kılavuz yazıldı
2 Yorum
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - Yanıt
can i use a nerf kronos spring
jordan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 12,640
