Ana içeriğe geç
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
Neye ihtiyacın var
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: adım 1, 1 resimden 1.
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      FixBot'a Sor
      Yorum Ekle
    2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: adım 2, 1 resimden 1.
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      FixBot'a Sor
      Yorum Ekle
    3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: adım 3, 1 resimden 1.
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      FixBot'a Sor
      Yorum Ekle
    4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: adım 4, 2 resimden 1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: adım 4, 2 resimden 2.
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      FixBot'a Sor
      Yorum Ekle
    5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: adım 5, 2 resimden 1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: adım 5, 2 resimden 2.
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      FixBot'a Sor
      Yorum Ekle
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: adım 6, 3 resimden 1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: adım 6, 3 resimden 2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: adım 6, 3 resimden 3.
      • Carefully pull the orange trigger upward and backward to remove it from the blaster.
      • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
      • Remove the spring from the rear of the trigger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
ericharman
1.440 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
ok, taken the spring out. now what?
Kelvin Mead - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 48
Her zaman: 10,166
